Window is stuck open, motor grinding noise
jenny1997
Car: 1997 Infiniti J30
Please help
fourdrinie
Car: 2019 Q50
The window motors are notorious for breaking a plastic gear inside...which can't be replaced, except for the whole motor....
you need to take off the door panel, evaluate whether the motor is not moving the wires from the window regulator assembly...or the regulator wires are broken....
not too bad of a job to replace either.....
there are many posts here how to replace...search is your best friend.
jenny1997
thank you!
