Hollett »
https://forums.nicoclub.com/hollett-u62455.html
Sat Jun 30, 2007 5:19 pm
i recently had a window prob, where they weren't going up. i did some reserch on mitchel on demand, and got the wiring diagram. first thing u should check is put 12 volts to your window motor, and see if the motor is gone or not. then if not, by chance its the problem i had, on the drivers door left hand side, there is a white plastick box with black tape. unscrew it, and fight to open it, it open on the end by cutting the glue away. in there are 2 contacts. clean them and test it out, u can test it without putting it together.
