It sucks to do all this work and get precisely nowhere. Anyways, summary I was rollin my window up one day and it kinda stuck halfway and made that noise, so I "helped" the window up by pulling on it and it went the rest of the way up. I rolled it back down to see what would happen and it went all the way back down then made that noise. Then I rolled it back up, and it did the same thing, got stuck, but I helped it back up. After that it was completely inoperable.
I went and bought a used motor/regulator from a 2+2 and put it on my car (2+0) after I tested the motor to verify it worked. I only swapped the motor onto my old regulator. I didn't think the regulator would need replacing because it looked good so I cleaned it and lubed it and put the new motor on, then reinstalled, and the SAME EXACT THING is happening again.
What could it be? Regulator? Would a 2+2 regulator fit on mine?
OH, to make it even better, I tested the old motor after I made this video and it worked fine
