KimberKenobi »
https://forums.nicoclub.com/kimberkenobi-u60342.html
Sun Oct 26, 2008 5:27 am
heh heh heh.
You can search for any wrap shop near your area (look for local radio stations that have vehicles wrapped and ask where they had it done)...
But I will warn you that if you place vinyl on the outside of your rear widow, your wiper will destroy it prematurely if you continue to use it.
A different option would be that if you are going to do a regular color (not metalic) then you could have the image cut backwards and applied to the inside of your rear window. Depending on your particular image and sizing/position, this may be illegal in your area due to removing rear visibility.
