lino »
https://forums.nicoclub.com/lino-u31679.html
Mon May 18, 2009 9:49 am
I took a chance and went for it. I replaced 7 out of the 8 window buttons. One refused to co-operate and I gave up after 2 1/2 hours. The fortunate thing is that it was the best one.
The pros of doing this job:
- It looks great to finally not see those ugly old rusted buttons.
The cons:
- It took much longer than I thought it would.- I highly recommend you take your time like I did, otherwise things can easily break.- Corner trim cover pieces, the triangular ones, are super brittle. Be careful!- You need the proper tools! Screws can get stripped if you think all philips screwdrivers are the same. I didn't have the right pair of vise grip pliers and that made the job unnecessarily more difficult.- I would recommend buying some door panel clips, the ones that push into the door. It's not surprising to find 1 or 2 broken in each door.- I don't know if the new ones are in tight enough. They look fine, but I'm not sure.- I would buy new bushings, washers and guide rollers if I were to do it again. That way everything is new. - I realize now why I'm not a DIY and how much I love my mechanic!
I wanted to take pictures and do a full write-up, but unfortunately I don't have a camera anymore. I tried using my old cell phone and it didn't work out too well. Here are some random pics from the job.
I'll post pictures of the end result in a day or two when the sun finally comes back. I can't get a good picture in this dark and gloomy weather with my phone.
