Postby
yodawill2000 »
https://forums.nicoclub.com/yodawill2000-u27169.htmlSat Jul 09, 2011 8:21 am
Any of you guys parting out J's have a Drivers door window actuator ??
I rolled down the window yesterday and it decided to not roll up.
I can hear the motor running but no movement.
Took the panel off and it seems nothing popped loose.
Not sure if you can adjust the clutch or if it even has one.
Postby
swimshark »
https://forums.nicoclub.com/swimshark-u57894.htmlSun Mar 31, 2013 5:56 pm
does it roll down quicker than usual and have play? ive had a motor stick on and tore the rubber gear up inside the motor. i can get a motor from pull a part if it hasnt already been scavenged.
