Wind Noise
kerrton
Car: 2008 Nissan Rogue SL FWD Gotham Gray
Hi there, please read my post with photos, full description of my discovery of the source of the noise and my successful fix. It sounds like the exact noise you are describing, just follow my fix and it should solve your problem.
acmm
Car: 2009 Nissan Rogue SL
Thanks for the feedback. I am usually pretty good troubleshooting wierd noises and the door seal theory was not on my list but I can't ignore your results and will try your solution. I would have bet my last dollar on the mirror but after looking at your pics it does line up with source of the sound and is adjacent to the mirror. I will definetly try. What type of seal did you finally use??
Iron Clad Lou
Car: 2011 Nissan Rogue SL
kerrton wrote:Hi there, please read my post with photos, full description of my discovery of the source of the noise and my successful fix. It sounds like the exact noise you are describing, just follow my fix and it should solve your problem.
can you point me to said post please? we have a wind howling noise as well that I'd like to fix. thanks
Harry2012
Car: Nissan Rogue S
I send my rogue in to Nissan Dealer today, Able to simulate the "Wooo" sound to the nissan tech.. He narrow down the root cause of the "woooo" noise to my windshield. Recommend to do a RESEAL for my windshield.. I m now waiting for the glass - guy to do a reseal.. hope it will work!
kerrton
For all those with the "wooooo" noise, I'd highly recommend you review my post with detailed photos on page 1 of this thread where I finally found the source of my very intense and troublesome wind noise and development of a solution that has totally eliminated the noise. The source was the drivers door seal as per my pics. I found this noise very deceiving and I can see how one would think it is coming from the windshield or the roof rails which was my suspicion for a long time, but eventually it was proven that the drivers door was the culprit. Luckily finding the problem was the hard part, once that was accomplished the fix is very simple - see page 1 of this thread.
Iron Clad Lou
kerrton wrote:For all those with the "wooooo" noise, I'd highly recommend you review my post with detailed photos on page 1 of this thread where I finally found the source of my very intense and troublesome wind noise and development of a solution that has totally eliminated the noise. The source was the drivers door seal as per my pics. I found this noise very deceiving and I can see how one would think it is coming from the windshield or the roof rails which was my suspicion for a long time, but eventually it was proven that the drivers door was the culprit. Luckily finding the problem was the hard part, once that was accomplished the fix is very simple - see page 1 of this thread.
thanks...mine seems like its coming from the moonroof, but I'll try your suggestion.
Harry2012
Car: Nissan Rogue S
Hi Kerrton, can i know where u buy those "foam tape"? i went to Auto Zone and Walmart today, cant find any of it.
ryancalif
Car: 2012 Rogue SV w/premium package
My wife's 2012 Rogue has the wind noise problem as well. VERY annoying... and embarrasing when you have passengers in the car. I've come to realize over the past few years that Nissan is notorious for weak weatherstripping and flimsy upper door frames. Our 2009 Versa, now 2012 Rogue, and a friends 2008 Altima all have wind noise issues during high crosswinds. The noise comes from the same spot on all cars - the upper rear edge of the door frame.
It occurs on the leeward side of the vehicle during a crosswind due to the low pressure region that builds on that side. You can actually see the upper door frame pull away from the vehicle when the winds are gusting.
Has anyone here found a fix? My car is a Subaru Forester and the door frame seems to be built more rigidly. No wind noise at all.
therealroland
Car: 2014 Nissan Rogue SL AWD + Premium Package; tan interior
While driving 65 or faster, very high pitched wind noise coming from the right rear of the car. Looked at how the panoramic sunroof was set into the roof, it is a couple of milimeters lower in the right rear corner, compared to the left rear corner. That could cause some wind turbulence as well, i,'m sure...
Return to “Rogue Forum”
