Wilwood master cylinder - which size bore?
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
IHeartTurbo
For those of you that have used Wilwood masters, what size bore are you using and why? .625", .700", or ,750"?
Joe
kinda depends on what engine your swapping.
IHeartTurbo
Kamin wrote:kinda depends on what engine your swapping.
Look at the sig - LS1 + T56
cnichols
Car: 96 Nissan 240SX
99 Infiniti Q45
93 Ford Fastiva
I used the .750...seems to work fine so far. Had it on the car since April and put roughly 4000 miles on it.
IHeartTurbo
cnichols wrote:I used the .750...seems to work fine so far. Had it on the car since April and put roughly 4000 miles on it.
I ordered teh 3/4" from Summit last night.
Joe
yes use a 3/4 bore
swap your pushrod from the stock master over, you may or may not have to make a new U bracket to attach to the pedal
i think chris needed one, i didnt.
Return to “Hybrids”
