Def »
https://forums.nicoclub.com/def-u8646.html
Fri Jul 09, 2004 2:37 pm
If you think a "bolt it in and forget it" Z32 upgrade has problems, then copying a Wilwood kit is NOT for you.
First of all, you'd have to be able to tell a machine shop what you needed, which would be very difficult if you aren't at least somewhat familar with technical 3 view drawings and dimensioning.
Secondly, you're looking at a MINIMUM of double the price of going full out on a Z32 swap, if not even more.
Unsprung weight is less, but it really won't be easy, and quite frankly, it doesn't sound like you've got the skills or knowledge to trudge through the project. Plus why expend all that money and effort on a dinky brake upgrade that can fit under 15 inch wheels?!?!
If you're just going to be using your car on the street, just get some better pads for your stock brakes and you'll be good to go.
