**WillADriveShaftfit??
cybertrn
Car: S14.5 & S13R
Will the Drive shaft fit from a 240SX 90(automatic) fit on a SR20DE-T Need to know!!Thanks
s13sr20chris
nope, the slip yoke is different. the center bearing will swap though if you get one that was a flood victim(like mine was). the driveshaft itself will have to be one from a manual. while im here i will move this to the rwd sr forum for you.
180fan
Car: 89 fastback
unless the SR is an auto also. Then it'll probably work, not too sure since I've never swapped an auto sr before.
cybertrn
Car: S14.5 & S13R
Thanks Guys!@ sWell
s13sr20chris
oops, i assumed you got a manual sr. good call 180fan. the auto sr prob would work with auto ka driveshaft.
<===='tard
