Will Z32 Or Q45 Brakes Clear My Drag wheels.?
Ali 556
Car: '95 S14 Se....
hay guys....i'm looking for brakes ''upgrade''....i'll be running DRAG wheels.....with big A$$ fat tyers...(not desided yet)...so the drag wheels are 15''......and i know that the rear Z32 cliper+rotor are bigger then the stocker.....so will they clear...?
setup....
'95 LS14 - T56 - Z32 LSD -etc etc etc....running for high 9's to low 10's
thanks'n'advance
Regards,
Ali
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
I got a q45 rear in now, with Z32Turbo axles, and q45 spindles, brakes and hubs. They should clear a 15 inch wheel. I am doing that same thing. Running a 15x12 wheel on slicks on track day.
FUNGC
OutToWinPAHC wrote:I got a q45 rear in now, with Z32Turbo axles, and q45 spindles, brakes and hubs. They should clear a 15 inch wheel. I am doing that same thing. Running a 15x12 wheel on slicks on track day.
what ebrake cables did you use?
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Well your gonna just have to make those work. Kind aliek making special throttle cables. Just clamp the two together. Right now the car is on a lift, I am putting in the cusco internals, I havent hooked up the e break yet. But right now it has a 15 inch wheel on the back. I still have alot of work to do.
cmfireman
Car: '96 Nissan S14 SE
With Z32 calipers, the diameter isn't the problem so much as the spoke design. Although the Q45's are smaller, this is also true.
About the only way to know for 100% is to test-fit a set of Z32 calipers before you decide to purchase them. I wouldn't recommend running spacers on a drag application because of the increased amount of torsion.
Ali 556
Car: '95 S14 Se....
cmfireman wrote:With Z32 calipers, the diameter isn't the problem so much as the spoke design. Although the Q45's are smaller, this is also true.
100% true...but you know....as i've promised you as soon i start i'll let you know right...?
the car is not here yet ....so i'm sourcing parts for the swap.......as of the design....i think i'll run ''star'' drag wheels.....and no way in hell that i'll run REAR spacer....i don't want to dye (yet)...lol
one last thing btw......dose Z32/Q45 clear the front steele(thin drag rims)....or should i run HUGE spacer inorder to ''bolt them on''....?
thank you all
Ali
Ali 556
Car: '95 S14 Se....
any one?
