Will this work??? LSD question
RatedR
Car: my beautiful young asian schoolgirl wife! Hehehheheeh, yes, its a "field trip". Yeah, a &q
Sup Fellas~! I know you have to switch out the flanges when doing an LSD job, but I was wondering if you could also just open up the pumpkin of an open-diff, swap in the LSD and get the flanges and make everything work.... I have a 93 FB, open-diff (obviously) and I'm looking to install an LSD for my next upgrade....
PS: here's what I'm talking about....this is the part that I want to just swap into my open-diff's pumpkin/case and make it work....
http://www.geocities.com/xxdre...3.JPG
Exar-Kun
Car: 2005 350Z
yeah, you should be able just to swap the internals from one diff to the other, IE the carriers for the diffy(your picture), and if your output flanges are in good condition, it *should* work fine.-chet
RatedR
So even if I have an open-diff, if I swap out the carrier it "should" work???? What would cause this NOT to work???? how about the flanges? do those have to be change still????
574-240sx
Car: Nissans, Toyotas, Subaru
i'm going to do the same thing i have the stock lsd diff off a 180sx. i just have to find the time to put it in i have only had it the past 5 months. Nick
RatedR
574-240: do you have an open diff???
Exar-Kun
Car: 2005 350Z
keep the flanges that are on the car now, just swap out the carrier. I dont see why it WOULDNT work, but new output flanges are usually recommended anyway.-chet
RatedR
What tools would I need to swap out the carrier? would I have to worry about any seals???? Any extra-precaution needed on certain parts???
MikeS14240sx
Car: 98 Nissan 240SX
Download the s13 or s14 fsm on zilvia.net. http://www.zilvia.net/faqs/faqs.asp
I know the s14 fsm shows how to remove and disassemble the carrier. Also has the precautions and warnings.
Does anyone know for sure if the slide bearing shims or bearing preload are affected after swapping differentials? does anything have to be adjusted?
Some of that stuff can get a little complicated. Thanks
574-240sx
i currently have a universal slip. Go one wheel burnouts. Haha.
RatedR
Well, I got the carrier...My question now is: Has anyone ever done this on their own??? CAN it be done on my own/in a garage??? I downloaded the FSM, and it stated that I need a slide hammer to pull the carrier. Other than that, I cant figure other things out. I have the carrier, but the picture shows it with teeth...I'm kinda lost from here on end. Any help would be appreciated. thanks~!
C-Kwik
I can't confirm this, but I speculate that the existing shafts will not engage a VLSD if that is what you plan to use. They may engage the spider gears but it may not engage the coupling.
Exar-Kun
Car: 2005 350Z
the 280zx lsd is mechanichal, I believe......not totally sure though.-chet
RatedR
Huh??? Chet, I think you have this post confused with my first thread about the 280zx....I have a JDM 180sx VLSD Carrier now....so will the output flanges still work??? Or should I go out to find new LSD flanges before I swap out the carrier?
Exar-Kun
Car: 2005 350Z
oh. heh. my bad. ask the guys at Jspec.com or even after-dark with your specifics, they will know of sure if the output flanges will work.-chet
RatedR
Yeah, I got a hold of some tech info from HT. Jeff says I would need the output flanges....sucks~!
RatedR
Now here's another twist, would it be possible to swap out the axles from a j30/z32 to fit in the s13 rear suspension setup??? Instead of the traditional output flanges, I think I'd be able to get a hold of a complete rear subframe of the z32 for cheaper...just a thought.
