turbo2nr »
https://forums.nicoclub.com/turbo2nr-u33029.html
Wed Dec 19, 2007 1:59 pm
if you have a sr20, it wont fit on the stock manifold, you need a top mount manifold flanged for a t3, you also need a manifold with a flange for a external waste gate. this turbo doesn't run a internal gate.
as for elbows, i assume you mean for your inter cooler piping and intake, you will need to fab up new ones. as for the down pipe thats gona be custom as well..
as well as if you need built internals. if you run alot of boost yes, conservative boost under 15psi on a sr20 then no.. as for what you would need, possible cams to get maximum efficiency at higher rpms...
