Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Thu Feb 22, 2007 3:57 am
Uh...why would you run spacers just to run spacers? A 17x8+35 doesn't need a 20 mil spacer by any means to fit. Running a spacer when you don't need to is like putting lifts in your shoes when you're already 6'8". Running an overly wide spacer is also folly. You're adding weight, effectively reducing offset, reducing wheel rate, increasing inner edge loading on any tire you do run, and messing with your scrub radius....
Crikey. Just get a set of wheels that fit without spacers, and fall within acceptable specs for the car you drive.
Also, yues those tires will fit, but you'd be better off, and have a much etter balanced handling car with equal rim/tire combos F/R and be able to rotate tires for better wear.
-Chet
