will this size fit the s14
inkslynger
Car: 1996 240sx
17x9+24 front and rear and what size tire???thanx
spanishricer
Car: '95 240SX & '03 M45
Well I have 18x8.5 +24 up front with 245/40/18 tires and 18x9.5 +25 in the rear with 275/40/18 tires.
With those wheel offsets, you shouldn't have a problem with the rear running a 255-265 width tire. The front is probably going to require running stretched tires (225 should be good) and spacers to clear coilovers.
98silvia
did you put a wide body on your car, are you sure those wheels will fit on a s14. because i am going to get some rims and tire for my car.
EazyBreazy
they should fit, tire choice may be limited in the front unless you roll and/or pull a little. but they will fit.
chmercer
the front will be kindof close to the shock, you might rub if you use a big tire. as long as you stick to like 245-255 you should be cool.
and that does not require widebody guy whos asking. thats easy fit on stock body, many would consider it sunk.
