SkillaSX wrote:Ok I want my car to reach the 200hp mark with bolt ons and slight mechanical work. Will this setup allow me to reach my goal?
Rebuilt Engine Ka24e
144hp
Apexi dual n1 exhaust----------------------9hpInjen air intake-------------------------------7hphot shot header------------------------------12hpUnorthodox lightweight crank pulley-----8hpMSD ignition system-------------------------4hpPerformance cams----------------------------5hpJWT ECU upgrade----------------------------8hpNGK spark plugs------------------------------0.25hpMoroso Ultra race wire set------------------0.5hp
53.75hp +144hp= 197.75hp
I pretty much guessed on all of those hp ratings, so If my car isn't at 200hp with all of those bolt ons, then what else should I add to my list.
Lemme reprase this.
Apexi dual n1 exhuast--$550-----5rwhpInjen cold air intake with extention-$250----3rwhpHotshot header--$330---8rwhpLightented pulley-$100---3rwhpMSD ignition-$250?-- 1, 2, or 3 rwhp, not sureNismo cams - $380 - dunno, 5rwhp max?JWT ECU Upgrade - $600 - lets say 10rwhp maxspark plugs - $40 - up to 1rwhp if your previous plugs were badplug wires - $??? - ???
Total cost: over $2500Total HP gain: around 40rwhp.
Now the KA24E is rated at something like 140hp/150tq. Assuming 15% drivetrain loss, that leaves you with 120hp/128tq.
Addin those mods, you get about 160-170rwhp at MOST.
These figures may be way off, but the point is that if you want a faster car, you will have to either do serious engine work or slap on a turbo kit. I know, because I have the majority of the mods done to my car already (and my friend's ka24e is fully decked out for N/A), and although a lot of the parts could be re-used when I go turbo (e fans, pulley, cams, plugs, wires, etc), I wished I saved the money for a turbo kit instead because that'll get you MOST HP PER BUCK, aside from running nitrous.
