Will this mafs fit?
JayDeeM
I have a 91 240 with ka24de and i was wondering if a 85-89 300zx mafs would fit on my car. And would it be any advantage to having it on a n/a car.
[s3]
no
C-Kwik
Making it fit wouldn't be the biggest problem. Making it work correctly would. I doubt the two MAF's uses the same voltage to air-flow ratio. So you would need some way of compensating.
If your MAF is working fine, swapping to another MAF is not going to yield any power. Typically, the reason to swap it is to get a MAF that car read a larger amount of air. Generally speaking, you'll find this more in cars with forced induction.
