steve s14 »
https://forums.nicoclub.com/steve-s14-u23089.html
Fri Jan 18, 2008 7:01 am
The harness layout is going to the body is pretty different, for example, on the s13, there are several plugs going to the body where on the s14, there is just one smj going to the body.Also the ecu plug is different along with several plugs on the engine. You can use the 97 ecu but you'll have a check engine light since s13's don't have an iat sensor and it's missing all of the evap parts that the s14 kouki's have. I don't remember all of the different plugs but i know the maf plug is different, the tps, o2, it's missing the swirl valve solenoid plug and i'm sure there is more but thats what i can think of off the top of my head.You can make it work but it's going to require extensive rewiring.
