Will this fuel injectors (16600-66U04) fit a 94 Q45??
Q45dude
Car: 94 Q45
I'm trying to find out whether the part number provided in the title area will fit my 94 Q45??
pabs324
Car: 94 Q45
On my receipt from IOS it has part number 16600-67u10
Q451990
Q45dude wrote:I'm trying to find out whether the part number provided in the title area will fit my 94 Q45??
According to http://www.fiveomotorsport.com...N.asp that's one of the part numbers that cross references to the 90-93 style injector. I would check with Joe or get someone to look it up in FAST to be sure, but if that p/n is indeed for the 90-93 injector it won't work in your 94. The 94-96 injectors use a different connector, and are a slightly different size so the fuel rail is different.
Heath
pabs324
Car: 94 Q45
The part number Igave you should be spot on. I just some from Joe back in April for my 94 Q45
Q451990
It seems that there are different colors... maybe dots on the connector? So there may be desirable to match any replacement injectors to the colors already in the car. I believe the injectors were flow matched and spray pattern matched - and that the color code indicates that. My understanding is that if you're replacing all eight - just match them all with each other.
Heath
Q45dude
Car: 94 Q45
Thanks. These are actually different color. I won't take my chances. I'll try to find same color ones.
