BuudWeizErr »
https://forums.nicoclub.com/buudweizerr-u1639.html
Sun Dec 05, 2004 2:15 am
you want to run squared tire?
235/40/17 front255 or some ungodly wide tire in the back. probably a 40 series as well.235 will be a mild stretch, but i wouldn't use much more than a 235 up front. thats my opinion though.
17x9 +15 on a stock fendered s13... you'll need camber, and if your car is low, like chuhhlie muhhhphy above me said, you won't be able to lower it much with squared tires.
just fyi, i have those same size wheels, i run -2.5f, -1.75r with 215/45/17 and my car is slammed. my fronts are pulled probably 5mm and my rears at least 10, maybe 15.
that size/offset is really good for drift stuff or grip with a minor overfender or a fender flare. if you just bolt that size wheel up without pulling/camber, the wheel/tire will stick roughly 10mm outside of the fender. it looks whack. so you have to massage them into the fender wells.
