will this fit??
Codeman05
Car: 92 240sx
will a stock S14 exhaust manifold and downpipe fit and S13 and still bolt up to the cat correctly?
TheOne
Car: 93 240sx FB
the exhaust manis are swapable but if you fit an S14 mani to an S13 it wont bolt to the stock downpipe as the S14 is 1 big tube while the S13 has 2 tubes.(this is all stock stuff)
so you can't get an S14 mani to put on an S13 or viceversa(sp?).
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
Codeman05 wrote:will a stock S14 exhaust manifold and downpipe fit and S13 and still bolt up to the cat correctly?
Are you talking about after market manifolds or stock?
1991S13
Car: '91 240sx Coupe, '00 QX4 4x4, '02 Sentra Spec V
I think S14's have another o2 sensor bung on the header that you need to plug if you are using it on an s13, too.
Codeman05
Car: 92 240sx
yea i understand that the s14 manifold wont bolt to the s13 dp but i was planning on using the s14 mani and dp to bolt to that cat.
i was told that this would work as long as the egr and extra 02 bungs were blocked off (the egr because it is in a different location). is that correct?
the reason that i am going to all the trouble is because a previous owner hacked off the cat in front of the flange and welded in a test pipe. Thus i have no where to bolt my new exhaust to. and i cant find an s13 downpipe for sale.
so i am trying to see if the STOCK S14 manifold and dp will fit on and S13 and still bolt up to the cat correctly and in the stock location.
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Yes, a complete S14 mani/DP will bolt up just fine.
And the S14 DP has the primary cat already in it, so you'll have 2 if you add another...FYI.
- Brian
Codeman05
Car: 92 240sx
thanks. yes i know the s14 has the cat already in it.
is there any way to eliminate it or punch it out w/o having to cut apart the dp?
