will this engine work?
joeatl
Hello, I recently bought a 240sx. The engine knocks. Doesnt rly harm the performance but i just want it to stop (and my buddy says it could sling a rod anytime). I found this engine on ebay, its a ka24e which is whats in my car. The only problem is that its for a nissan stanza which is FWD. Can it go into my car using my transmission etc?here is the link:http://cgi.ebay.com/ebaymotors...sting
ShootToKill
Car: S13
No, It will not work. just get one from a running 240, they are not that hard to find.
joeatl
also i was just reading other post and they said something about lifters, maybe i will try some motor flush also.
Vegascorbin
Car: 1990 240sx dirt track race car
If you can afford the cost (1,000 to 1,500) depending on the work required and your location I always recomend rebuilding what you have.
A good rebuild of a stock KA24E will be stronger than most other used engines.
Other option is just swap in a used engine and be done with it.
whits
is the bellhouse bolt patern differnt on the fwd then the rwd?altima, to the 240sx or the hardbodie p/u. im lookin at gettin a ka24de to drop in my s-10 p/u. i know they used them in the altima from 93-01 but wasnt sure if they change the bolt patern for the trannys or wut not.
whits
they also used them in the nissan hardbody p/u but there hard to find up here in canada, and 240's are just as bad to find for cheap.
KGB
Car: 1989 Nissan 240sx & 2007 Ninja 650r
that knocking may be preignition. IT also can be something messed up in one of your cylinders bores: piston pin, rod. Tear down the engine and youll find it. if its that, if its not and its preignition, step up the octane
joeatl
I did a motor flush, during the motor flush as soon as it hit the 4.5 min mark, i heard the noise go in half. Then y buddy took off my valve cover and lossened my rockers, then torqed to specs and it doesnt make any more noise!
Romeo_rus
Car: zenki RB25DET - SOLD, zenki SE ka24de - wrecked, zenki - sold, GOLD ZENKI - WILL LIVE FOREVA
Hey, this engine will fit your car http://cgi.ebay.com/ebaymotors...ZWDVW
