Peabody »
https://forums.nicoclub.com/peabody-u10351.html
Thu Aug 31, 2006 7:45 pm
Hello, I have a 90 240sx with 150,000 miles. I was having problems when I was driving under 3000 RPM's or not at heavy throttle. The car would jerk, shake, and just run very bad. I read that if you took off the MAP sensor and clean it that it might fix that problem. I did and it ran great with any problems. I decided to clean the throttle body with cleaner and then I had a stupid of using the cleaner in some vacuum lines around the IAA Valve. Don't ask me why I did that but I sprayed the stuff in 3 hoses in the back of the intake. I am sure I got some cleaner in the IAA because now It idles at 1350 RPM and I cannot get it lower with the adjustment screw. When I put the AC on it does not make the idle go up. And when I come to a stop after I take my foot off the clutch the idle will drop to 500 RMP and every 20-30 seconds it will rise to 1000-1350 with the AC off. What can I do to fix this problem? Can I take the IAA valve off and clean it with the correct cleaner (whatever that is) or did I screw it up and it needs to be replaced? I tried to take the sensor plug off to adjust the idle put I could not get it off. The had 2 plugs aroung the IAA and I was not sure which one to take off to try to adjust the idle. ANY SUGGESTIONS?Thanks,Michael
