Will this combo work?
Slipstream
Car: '94 Sonoma, '90 300zx n/a
I have a dilemma. Running short of money for my build for now, so will this combo work for awhile?
The good:p&p head+1mm intake/exhaust valves (BC)Springs/Retainers (BC)Eagle rods86.5mm Wiseco pistonsJWT valve guidesXSPower ManifoldPolished/balanced crank264/264 BC Cams87mm/1.8mm GReddy head gasket550cc injectors
The Bad:S13 T25S13 sidemount ICProbably run a stock ecu with a tune, don't have one yet
Will this combo burn out my turbo too fast?
S13FASTBACKSR
Car: '92 Fastback SR powered
if u havent done the P&P yet i would leave that out thats a lot of money with that you could get a front mount and the valves arent necessary stock valves are good for over 500 horse i wouldnt go with a greddy HG havent heard good things get tomei or apexi and also i would try to scoop up a t28 atleast but i mean if a t25 that will be fine i mean it would work
Slipstream
I have everything listed, I'm just afraid of maxxing out the turbo right after I install it. I would like to go with a gt2871R, but work is slow, so no extra money.
S13FASTBACKSR
your turbo will be fine just dont drive hard drive like a grandma...u could just put stock cams in and injectors and stock tune for now until u save up u know
luv2spedup
Car: 89 silvia
fmic is very IMPORTANT
S13FASTBACKSR
ya...if your planning on boosting more than 12-13psi...a smic is fine you just have to know its limits
