will this bolt right up?
black180sx
Ok, first off I have searched alot without much success so... I have a 1990 240sx hatchback and next week I am picking up a rear subframe from a 1989 ca18det powered 180sx (japanese spec) with a lsd. I know the final drive is 4.36 on this rear end. I want to know if this will bolt up directly to my car. Both use 6 bolt out put shafts/axles. I do not know if it is a r180 or a r200 like mine. What do you guys think? thanks for the help in advance.
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Same chassis (S13), same subframe...despite what country it came from.
Use the whole subframe, use just the diff/axles (I'll bet it 5-bolt...every 4.36 diff I've seen has been 5-bolt).
No 240SX/Silvia came with an R180, so you're in the clear there...
- Brian
black180sx
ok so it has to be an r200. cool. The guy im buying it from says it has 6 bolt axles, maybe hes wrong? either way i could keep my axles or just use the ones off the subframe i suppose.
