Will this be able to push back the front caliper pistons
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Will this tool work on the front calipers: http://buy1.snapon.com/catalog/item.asp ... ir=catalog ?
I already got the Craftsmen version of this tool (because Sears is closer). But before I attempt the job I would rather be sure. Lokim I bet you will know for sure!
qship96
Car: 1996 Infiniti Q45
Yes, that is the tool I own, works well.
yodawill2000
Car: 94 Infiniti J30
Simple C-Clamp on the old pad always works for me. :gapteeth:
kevindanielk
Car: 1995 Q45 Stock, except for the blues.
Yep, what yoda said. Simple large c-clamp, squeezing in the old pad, will push both pistons in at the same time.
Q451990
Ditto on the c-clamp - no special tool required.
Heath
RustyBucket
Car: '94 Infiniti Q45
I've used the special tools as well as just a C-clamp and I'd have to say that the C-clamp is just as easy.
Actually, I've done it by hand without even a C-clamp before. I put my 19mm wrench across the piston, put my palms against the wrench, grabbed the back of the caliper with my fingers and squeezed. It worked to push the rear caliper piston back in, although somewhat slowly. It's defnitely not the right way to do it because you could potentially push it back in unevenly and cause binding. All I can say is that it worked for me. :gapteeth:
qship96
If you are looking for cheap quick way to push pistons back in using tools you already have, a pair of channel lock pliers applied to the old inserted pad work also. Proper tool works as designed,but their are cheaper alternatives that will get the job done!
