Will They Fit?!?!
hoover86
I hate to do another will they fit thread but I’ve stared at numbers from all these different calculators and feel like I’m getting nowhere so here I go...
I have a base M56 with stock 18’s currently. I’m also running stock suspension.
There’s a guy selling 20” TSW 10.5 +25mm with 275/35/20 front and 305/30/20 rear.
WILL THEY FIT WITHOUT RUBBING?!?!
Kprad12
Car: Infiniti M37
I can't tell you if they'll fit but that setup would have the front and rear tires at different diameter than stock and your speedometer would be off. For 20 inch rims you would want the middle tire spec to be 40 to keep an accurate speedometer reading. Go here http://www.rimsntires.com/specspro.jsp put your stock setup into that and when you input the new setup it will tell you how much space you need. Then go to your car and see if it can fit. I am fairly certain that setup will not work but check.
