Rikter »
https://forums.nicoclub.com/rikter-u66899.html
Thu Mar 13, 2008 6:25 am
Hi Folks,
I'm hoping some help can be found here. Regardless of the outcome I'll have to bust off the wheelnuts anyways(wheel locks on the wheels with no key... GRRR! ) but I'm wondering if someone might know if I can do this or not.
Specs:'89 240SXJDM Tein HA’s 10kg/mm, 16-way dampening adjust, upper camber platesS14 front and rear 5-lug conversion (hubs and spindles)Z32 (300zx twin turbo) front brake conversion (4 piston calipers)17x9 +5 (with 30mm spacer) Bronze 5Zigen FN01R-C’s w/ 215/40/17
The original owner had all that stuff put on but because of the spacer, the wheel/tire sticks out a little past the fender and I want to suck it back in. Does anyone know if I can remove the 30mm spacer and the wheel will clear the caliper as well as not rub on the suspension/fender liner/etc?
-Rik
