beachbum718 wrote:I know someone with 20x10.5 +15 but runs 245 35 20 tire.and it fits no fender work. Hes on coils and really low..so they will fit.but your awd so you need f&b wheel diameter to be exactly the same.and that will be kinda hard matching tire sizes to get that diameter the same, since your rear is 20x10 and front is 20x8.5..id pass on them.forget the headaches.buy real rims not off the shelf 1 pc rims ether.
lol. It's really hard to take this seriously when you say "buy real rims not off the shelf 1 pc rims ether"
So a 1 piece forged wheel is inferior to a 3 piece "cuztum" wheel?
OP, your offsets are very aggressive and would probably need fender work or negative camber to get it to work. You have the spacer/converter thing...I would keep it simple and look for wheels with the correct fitment. Front and back diameter need to be within 1% of each other if you want to run staggered on AWD. It's not impossible and people do it all the time.
