will these wheels fit!!!!?
All things Altima Coupe.
illestcoupe10
Car: 2010 2.5 coupe
TSW willows
Size
19x9.5 +20 215/35/19
i have 2010 altima coupe 2.5s
HELP!! :confused:
IBCoupe
Car: '08 Nissan Altima Coupe 3.5SE
'19 Infiniti QX50 FWD
'17 BMW 330e iPerformance
You might run into a little trouble in the front. Planning to stretch the tires? 215 is pretty small for a 9.5"-wide wheel.
illestcoupe10
Car: 2010 2.5 coupe
what would be like perfect fit? someone help lol
im looking into getting wheels and tires soon
and im also getting coils in the future so i need to plan for that as well. im on eibach springs right now
Blackmobile
Car: 2008 Altima Coupe 2.5S Super Black
what offset are the wheels? with a 9.5" rim, you want to go atleast 240
IBCoupe
Wheels are +20, he said. I think that means he's going to be 17.5mm out in the front (3/4") and 12.5mm (1/2") out in the rear. Might be okay in the rear once the coilovers are on, and if he cambers it, it could be doable in the front, too.
AlexM.
Car: 2010 Nissan Altima Coupe 2.5 Super Black
How low are you gonna go?
AlexM.
IBCoupe wrote:Wheels are +20, he said. I think that means he's going to be 17.5mm out in the front and 12.5mm out in the rear. Might be okay in the rear once the coilovers are on, and if he cambers it, it could be doable in the front, too.
He might be limited in the front with negative camber. I believe the max neg camber I could get out of my coils is about -1.7 and I still wish my fronts could sit further into the wheel well. I think rears will be no problem like you said IBC cause of natural camber + negative camber via camber arms if necessary.
OP it really depends. Give us more info on what you're trying to say.
Blackmobile
duh yeah i missed that... i need to learn to read better. anyone else think these are going to poke unless the OP is ok with putting some camber on his wheels?
i'm at +30 with 8.5" rims and they're very close to flush.
alphapig
Car: Nissan Altima Coupe S 2.5
Those look cool
9.5 +20 sounds delicious for the rear. After a trim or roll.
Look for something like 9.5 +35 or higher for the front. Also after a trim or roll.
:bigthumb:
illestcoupe10
Car: 2010 2.5 coupe
thanks for the help guys. i doubt ill go with these wheels tho cause i want some WORKS(: VS-XX
