Will These Wheels Fit my Stock Suspension?
jamied311
Car: 91 Nissan 240SX Fastback
Im looking to get a set of these in 17 X 8.5 all around +20 offset... I just wanted to know if they would clear my stock suspension?
http://www.aspecproducts.com/images.asp?theid=6428
teddy
Car: Saab Turbo and MR2
The rears will fit just fine. The fronts I'm not sure about. The 20 offset helps pull the wheel out, and I want to say they'll fit fine, but I'll let someone who knows for sure tell you that.
naed240sx
Car: .....
Wow a 4 lug, good offset wheel that is relatively cheap. they should clear your suspension, but you will probably have to use a roll or slight fender pull up front.
Dori Dori
Car: Cars of course
Yes, the wheel will clear but depending on the tire size you're running you may rub the front suspension. If you stretch a 215/45/17 for example, you should be fine.
jamied311
would a different offset make it any better? I really dont think i wanna roll my fenders if I can aviod it...
they have these in +15,+20,&+30
nismofly
Car: 89 Nissan 240SX Hatch
well the +30 would be a very tight fit, doable but you probably wouldnt want to run more than a 225/45 tire
the +15 would just be that much more youd have to mod the fenders
its up to you
Kouks
Car: 1996 Nissan 240sx S14 Sr20det
those are good lookin, what they got cookin?
chmercer
i dont even know why they make the 8.5 width on that wheel. please buy the 9j. PLEASE.
