will these volks fit?
s14tan
Car: 95 ZenKi SE w/ S14 SR GT28r and bolt ons
will these volks fit or do i needs to buy over fenders? where can i get them for cheap?
This set includes 18x8" (+43 offset, Face-1) front 18x9” (+37 offset, Face-2) rear$2,556.00whats the diffrenece between face 1 and face 2?
and the center caps cost an arm too Volk GT Center Cap$120
eds13
Car: 89 240sx Hatch, 07 Armada LE, 91 Skyline GTR
DO NOT BUY THOSE WHEELS IN THOSE SIZES!!!!
30mm and 40mm offsets are way too high on a S chassis. go with a 9 in the front +17ish and 10 in the rear with +20-25ish. that will look really sharp!
adrianfromthecastle
Car: 1992 Nissan 240sx
s14tan wrote: 18x8" (+43 offset, Face-1) front 18x9” (+37 offset, Face-2) rear
haha... not even close... to flush
s14tan wrote: will these volks fit or do i needs to buy over fenders?
more like under fenders!
s14tan
lol im not that good with rim offsets what would happen if i get those sizes? you said the car will be raised?
what would i need to do to make them fit?lower the car?
yes im a wheel noob
o n those are the only sizes they have...where else can i get them for cheap in a size that fit?
can u help a noob out so this wont happen again and tell me whats wrong with the sizes? please thanks
Modified by s14tan at 6:09 PM 6/25/2007
adrianfromthecastle
offsets homie... offsets...
although, I'm not too familiar with s14 offsets, I can tell you straight out that those offsets given are gonna be sunken in.
stickiez up top joo n00b! wrote:The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types.
Zero OffsetThe hub mounting surface is even with the centerline of the wheel.
PositiveThe hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
NegativeThe hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly. We have test fitted thousands of different vehicles for proper fitment. Our extensive database allows our sales staff to offer you the perfect fit for your vehicle
I'd guess the offset your better off with is 8" width with a +0 offset or 9" width with a +10 offset or something along those lines...bottom line... lower offset for you car is what you want. none of that +40 crap
sip
Car: Impreza STi GC8
RX7 twin turbo
1974 Mazda RX4 3 rotor
2014 Forester XT (Baby Hauler)
www.drluc.ca
s14tan wrote:lol im not that good with rim offsets what would happen if i get those sizes? you said the car will be raised?
yes im a wheel noob
Go to the Wheel FAQ and read some terminology, that will get you started. The offset number (+43) is how much the wheel is sunken or how far it sticks out. The higher the +number the more sunken in the wheel well the wheel will look. The stock offset is +40, so a +43 offset will be more sunken than stock (by roughly 3 mm given the same wheel width, if the wheel width is different that effects things too; wider wheel with same offset will stick out more than stock)
If you want to bring the wheel out to give your car a wider stance then you want to have a lower offset. Mine for example are +08 in the rear +25 in the front. Both stick out farther than the body fender.
zerothread/259538
I like the look. Some like to tuck their wheels, some like them to stick out. Look at some pics and decide what you like. If you have any questions.
Damn, adrian beat me to it.
s14tan
adrians_s13 wrote:offsets homie... offsets...
zerothread/259538
WOW YOU GUYS REALLY HELPED!! IVE LEARNED SOMETHING TODAY! YAY ME I THOGHT THAT THE HIGHER THE NUMBER THE MORE IT STICKS OUT I WAS THINKIN THE OPOSITE
SO I WANNA SEE IF IM STILL WRONG.......FRONT 18X9+20?REAR 18X10+10?ON A S14....RIGHT WRONG OR WARM? (O I PLAN ON BUYIN SOME USED CHARGE SPEED 50MM OVER FENDERS FROM A FRIEND HOW WILL THAT AFFECT MY SIZING?
DOES ANY BODY KNOW WHERE I CAN GET A SET OF VOLK GT-C IN THE RIGHT SIZE FOR THE RIGHT SIZE?
adrianfromthecastle
warmer... that size would be more flush... but obviously, if you put overfenders on, its not gonna be as flush...I'd go with that size and ditch the overfender idea... over fenders are for baller sizes
yokota180sx
Car: 1997 Stagea RS4, r34 front
what od you dirve?a minivan?
s14tan
adrians_s13 wrote:warmer... that size would be more flush... but obviously, if you put overfenders on, its not gonna be as flush...I'd go with that size and ditch the overfender idea... over fenders are for baller sizes
yeah i was thinkin that too when i woke up todaybut i want the wheels to protrude from under the fenders a lil bit so is +15 front and +5 rear ok or a lil much just tryin to get it right..
sip
RX7 twin turbo
www.drluc.ca
s14tan wrote:yeah i was thinkin that too when i woke up todaybut i want the wheels to protrude from under the fenders a lil bit so is +15 front and +5 rear ok or a lil much just tryin to get it right..
Depends on what you are going to do with the over fenders. remember they will cause the wheels to sink in by 5 cm or 2 1/4 inches. So if it just sticks out on the stock body then it will look sunken withthe overfenders on.
Is it just the rear that will have wider fenders? Are you positive you want a wider body?
s14tan
i dont know i cant find any pics of a white zenki with charge speed over fenders you have any?
yokota180sx
do you even do any motorsports where you will require a 10 inch rear wheel?
or have enough HP to drift on it (if thats what your doing)
my guess is no
s14tan
yokota180sx wrote:do you even do any motorsports where you will require a 10 inch rear wheel?
my guess is no
why are you always criticizing people?for your information I plan on building a street/time attack car.just cause people don't do the same things you do like forcing a set of 17 in. tires onto a set of dubs don't mean you gotta hate....lets just face it this way, its not your car you dont have to like it. im not trying to be mean but its my car and if i wanted to i can turn it into a dualie but like i said no disrespect to you tho you give good advice but your like Simon from American Idol (and thats not a good thing).
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
Over fenders are unecessary in my opinion.
The offsets you want to run are...
Wheel Size X 9" + 15/20 up front
Wheel Size x10" +15/12 out back
s14tan
where can i get rims in that size for a good price?
yokota180sx
s14tan wrote: why are you always criticizing people?for your information I plan on building a street/time attack car.just cause people don't do the same things you do like forcing a set of 17 in. tires onto a set of dubs don't mean you gotta hate....lets just face it this way, its not your car you dont have to like it. im not trying to be mean but its my car and if i wanted to i can turn it into a dualie but like i said no disrespect to you tho you give good advice but your like Simon from American Idol (and thats not a good thing).
no dude, you ask do i need overfenders?your trying to get it right im the guy to helpdont be a d!ck to me
You said 5 posts up you wanted to see pictures, so obviousl you arent too concerned with use if your that worried about asthetics im all about helping, but your not helping yourself
Modified by yokota180sx at 7:47 PM 6/27/2007
yokota180sx
whats a good price?\
s14tan wrote:where can i get rims in that size for a good price?
s14tan
DEAL n im not tryin to be a d!ck either
ive searched for a set of volk gtc's but i wanted to know if any one else can find a better price the lowest i found was 2k.
yokota180sx
why ar eyou set on volks?
s14tan
ive always liked them n iv always wanted to own a set...unless i can find some repelicas...
yokota180sx
let me do some looking around
yokota180sx
9ï½¥10X18/114.3-5H/+242300 shippedand a much more ideal offset
BOOMSHAKALAKA
Enduro Motorsports had some of the cheapest prices for Volks last time I checked. Don't know if they have them in the size you're looking for but they do have a sizing chart on there so you can look for it on there...
...and for the love of God dude, SEARCH. You might as well kick the creators of search engines in the nuts because you're not utilizing them to their fullest potential. Google Volks, Volk GT-C, etc. It's not that hard.
adrianfromthecastle
yokota180sx wrote:9ï½¥10X18/114.3-5H/+242300 shippedand a much more ideal offset
OoOoo... and with centercaps I see...
damN!!! I wish we had upgarage...
s14tan
adrians_s13 wrote:OoOoo... and with centercaps I see...
i know thats a preety good price...we get all the bootleg shops lol
yokota180sx
thats a price for youi sell wheels lol
s14tan
arae you serious?
yokota180sx
do i ever ****ing kid?if you want them Email [email protected] can have them shipped to you in a week
s14tan
what size are they?
