WILL THESE SIZES WORK
inkslynger
Car: 1996 240sx
FRONT 17X8 235 40 AND REAR 17X10 255 40??????????
Fenvy
Car: 2005 350Z Base 6MT
yes
inkslynger
Car: 1996 240sx
is the rear going to be shorter or will the front and rear be the same heightthanx for the help......
SeVa-S13
Car: '05 GTO 6spd
What offsets are those wheels? And those rears will not fit if it's lowered, no matter the offset. You'll need to pull the fender and run a decent amount of negative camber.
Your rear tire will be taller than your front.
Fenvy
SeVa-S13 wrote:What offsets are those wheels? And those rears will not fit if it's lowered, no matter the offset. You'll need to pull the fender and run a decent amount of negative camber.
he didn't specify what car, I believe he was just asking whether the tires will fit on the rim...
SeVa-S13
Car: '05 GTO 6spd
Well he has an S14 and it's in 240 technical so I was trying to connect the dots.
Fenvy
how you know he has s14?
SeVa-S13
Car: '05 GTO 6spd
Magic. (zer...28525)
NYCRB240sx
Car: Car, girls, snowboarding, skiing, sports, beach
ya your tire size should be fine. i have front 17x8.5 245/40, and rear 17x9.5 255/40
