Will these rims work?
1994JDMZ32
Car: 94 300zx
So I'm looking at picking up these rims but not sure if they will fit, and the seller doesn't know the offset.
They are 17x9.5 front with 245/40/17 and 17x10 rear with 255/40/17. He says they were off of a Mk. IV Supra if that helps. I guess basically what I need is what ranges of offset will work with those specs and I'll have to measure when I go look at them. I'm more concerned about the front. My car is stock height and I don't plan to ever lower more than maybe an inch.
NolimitZ32
Generally WHEELS that fit a Supra will work on a Z32, however Supras can fit some crazy offsets that the Z won't. Asf or what will work, I suggest you check out rimtuck.com from there you should be able to extrapolate exactly what will and won't work.
