Will these rims fit a 94 Q45??
Q45dude
Car: 94 Q45
Offet +45Bolt pattern: 5x114.3 and 5x100
will this fit a 94 q45???
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
What's the size? Offset doesn't mean anything without knowing wheel width.
I imagine they'll probably fit, and with a 45mm offset they're probably around 7 inches wide? Should fit fine in that case.
Q45dude
Car: 94 Q45
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Are you sure? That's a REALLY bizarre size that would have almost no sidewall whatsoever. Tread width doesn't say much about wheel width, though, especially with the stretching people do these days.
You don't have the actual wheel measurements, like 18x[whatever]? Sorry to make it harder than it should be...but that tire size seems too odd to be real and even if it is real it doesn't tell us what the wheel width is.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Q45dude wrote:215-35-18
Load index has to be way too low, not to mention they would ride like rubber bands on skate wheels.
Weight? Strength? Chances are if it has two bolt patterns it is made for a much lighter car.
rhinoone
It will bolt on your Q, however, see the above warnings about size and strength.
The Q has a 66.1mm center hub, and the wheels are suppose to slip over the hub for a hub centric fit. Universal wheels usually have a center hole too large and you need to buy hub centric rings $20-$50
Rex
Car: None
That's the tire width, to accurately tell "how they'll fit" you need the wheeld width.
My guess though is that any wheel running that size tire has been use on a VW with adapter/spacers, thus (as a guess) the wheels will probably fit, but the tires are basically useless for your car.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
agreed. We really need the wheel width, probably 7in if I had to guess, which is really too skinny. I dont like any skinnier than 7.5 to get a 245-45-18 on there.
