will these injectors work? (pic inside)
htown240
Car: cars, freeskiing, and of course the ladies
Hey, I just got these and wanted to know if these were drop in or not. If not, what customization needs to be done? The guy said they were from a silvia.
andrave
Car: 1989 Nissan 240SX Coupe
your pic is dead, if they are off an sr20det they are high impedance 370cc side feeds that bolt into the stock rail on a ka24de.if they are off a ca18det they are top feed and they bolt into a ka24E.
htown240
sorry for the dead pic, hope this works
nismo1003
Car: Ka24de
yes, they are 370cc high imp , they will fit .but u need some new O-rings from the dealer
htown240
ok thanks, just get o-rings for the stock injectors right?
andrave
yep. you can get them from napa too. might be cheaper than dealer.
LongIsland240
Car: 92 S13 Hatch
......or if you're real ghetto, reuse the stock o rings! ;)
Jookmasta
how much do O-rings run?
nismo1003
Car: Ka24de
they don't cost much (even I bought them at Courtesy Nissan ) , and please don't resure them , I had so much trouble with those the reused one . I suggest you should change them out to a NEW one whenever u take them out for any reason , at least inspect them.
C-Kwik
LongIsland240 wrote:......or if you're real ghetto, reuse the stock o rings! ;)
Just to clarify, he's joking. Or I hope he is. Gas makes the o-rings brittle. You should not be reusing them at all. Unless you want fuel to leak past the injectors...
bbandit
do you all think its possible to get just that injector plastic cap? (bottom cap)i have a set of 370cc but i lost one of the caps in one of the injectors...I went to nissan dealership and they told me that they can only sell an injector as a whole which is 140 something...
nismo1003
Car: Ka24de
yeah they called those pital cap, U want them just to keep the o-ring in place( it may serve other purpose , u can use those 270cc pital cap to put on to ur 370cc , it is kind of hard to take it out thou, if not u can try to call RC Engineer , they do sell it , but u hve to send them in and they will insert it for u. NO u can't just buy it thru them, i tried. by the way, I don't think it is needed , what is import is this thing, it has to be straight around , otherwise ur o-ring wouldn't sit right and it will leak thru there. picture below is what I am talking about
nismo1003
Car: Ka24de
here is the picture
