Will these injectors fit?
DawgMode
Car: 180sx
Wassup,Will injectors off of a wrx sti fit into my 93 redtop if i get the top feed fuel rail???Also does anyone kno if these injectors are high or low impedence???
crazys14mexican
Car: 95 240sx, 2004 spec V
i had the same question...but its some injectors off a wrx
hannibal
Car: Red Line to Glenmont
I assume yall are talking about the current WRX and STi, and not JDM versions.
I thought the STi injectors were hi impedence yellow top 565cc (550cc?) side feeds. They require different clips/plugs that can be found on the 2.2L Legacy.The WRX injectors are 420cc top feeds. CrazyS14, look for 550cc Mazda FD injectors. They have purple tops.
This is based on info Ive gathered off the net. I personally havent used either injector...
virus77
Car: 95 S14, 71 240z, 97 e320
I run the yellow top 04 wrx sti side feed injectors on my kat, I just made my own clips. Same rail as an SR so it will fit on a stock rail, unless you mean the JDM Sti injectors, which are top feed, and USDM spec wrx non-sti injectors are top feed.
