Will these fit
Cruiz82
Car: 2018.5 Nissan Rogue Sport SL
I'm terrible at math... anyone smarter help me please? Can I swap from 225/45r19 to 225/40r19 safely?
Lone Wolff
Car: 2015 Nissan Rogue SL AWD
2025 Toyota Corolla Hybrid
2010 Ford F150 Lariat 4x4 5.4L
2010 Ford Fusion SEL
1968 Firebird 400
Try some numbers here and see if that helps.
https://tiresize.com/comparison/
Cruiz82
So will it not safely go on if it's slightly outside of 3% mine shows 3.3% difference and +26 revs
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
I don't think it will be unsafe as long as all 4 are the same and meets the load rating . Speedo will be off, ride will be slightly rougher and more wheel gap.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
itsa300zx wrote:
Fri Mar 18, 2022 3:27 pm
+1, Nissan ABS's and clusters don't care about absolute tire size, just relative. If all 4 are the same rolling diameter then everything will work fine and there will be no codes, you'll just have a speedo error.
Return to “Rogue Forum”
