Will these fit?
naladude911
Car: 2001 Infiniti QX4
http://hudsonvalley.craigslist....html
fueler
Car: 2 Nissan's
2 BMW's
the chevy lug pattern is the same as qx4's, so lug-wise they will fit. The thing with chevys is they have really tiny hubs, 73mm to be exact while qx4 has 108mm hub. So you would have to make sure the hub (the hole in the middle of the wheel) is at least 4 inches in diameter to fit your car..
Having that said, they both have flaws. The first set has a bad tire which is gonna cost $200 more.. the second set has all 4 bad tires which is gonna run you at least another $800
I dont know about new york but here in san diego, theres tons of mexican rim shops that would hook you up with brand new dubs for under a grand... granted theyre chinese cheap s*** but the same chinese rims cost twice as much at discount tire AKA americas tire
Pwnin O'Brien
Dude, you have got to stop doing this. Use the wealth of information on the internet and Google that s***. All you have to do is Google 'Chevy Tahoe bolt pattern center bore' and I'm sure you will find hundreds of pages telling you the bolt pattern and center bore size of a Chevy Tahoe. You already know the bolt pattern and center bore for the R50, so all you have to do is compare the two and if they match then they will fit, if not then they won't fit. How are you possibly going to pass any engineering courses if you can't do this simple task?
JonathanPrem
Car: 02 Nissan pathfinder 4WD SE
Second set might rub
naladude911
we do have those shops, all over the bronx but they are in very sketchy areas. Ill probs have my subs jacked before I can say rims
Dyjacu
not at all, there are people with way nicer equipment than you that roll around every day in the bronx with no problems, or you could just go to one thats not in such a sketchy area
