will these fit
Warriors240
i was looking at some 215/45 r 17 and was wondering if they would fit on these rims 17X7 also would they fit on a 93 240sx se?????
SmithSR
Car: 240sx
215/45-17 will fit on a 7" wide wheel. Will they fit on your car? As Exar has stated in another thread, "you won't know until you test fit"
My guess is they are probably a higher offset, as generally, most aftermarket wheels nowdays are made to fit the most common vehicles....Honda....
High offset wheels fit nicely on FWD, not so well on 240sx. Suspension clearance may be an issue, use caution.
-Phil
