nismofly »
https://forums.nicoclub.com/nismofly-u19497.html
Wed Mar 21, 2007 8:24 am
the higher offset makes it sit closer to the suspension, a lower offset lets it clear the suspension better but it means you need to do fender work to fit it
so itll clear the fender better but when you start getting to this point width wise you get to the point where you have to do fender work to let the wheel sit far enough out that itll clear the suspension if you have coilovers
so like i said, if you ever plan on getting coilovers, youll want the +17
