will these fit. nned to know soon
nomore_mr2
i am gonna purchase a set of volk rims. i have them on hold but not sure if they will fit. i know the bolt pattern will but what about these sizes. front 16x7 20mm offsetrear 16x8 22mm offset will thise fit on my s13 and say i wanted to go coilovers in the future will they clear coilovers?
Exar-Kun
Car: 2005 350Z
yes, they will clear no problem, but they'll look really silly, because you'll have about a 3/4" to a 1" lip sticking out of your fender.-chet
nomore_mr2
hey what are good offsets for a s13 then. also thanks for a quick answer.
Exar-Kun
Car: 2005 350Z
in a 7.5 a 30mm offset is exatly 1mm closer to the shock mount(very negligable)
I have 17x75. a 16x7 or 16x7.5 with maybe a 32mm or so offset should be fine. if you get a 16x7 get a 35mm offset(roughly)
it really depends on what your goal is. what are you going to be doing with the car? are you going to put coil overs on it? Z brakes? etc..
-chet
nomore_mr2
well as much as i dont wanna say this i am into highway racing adn drag racing then anything. these wheels i found look amazing and i really like the style. i just want a nice set of 16's 7 front and 8 rear. i will eventually putting coilovers on teh car and wanan make sure i get something that will clear. i am not sure what my possiblities are with brake upgrades yet but i know i wanna stay 4 lug.
240Degrees
i already have coilovers on my fastback. will that 35mm approx. offset be fine?
Exar-Kun
Car: 2005 350Z
in a 7" wide rim, yes.
if you really like the style, get them, Im just telling you the lip will protrude past your fender a bit, I dont know if it will fit Z brakes because I dont know the design of the inside of the rim(taper), but for highway racing, you shouldnt need oversized brakes anyway.
-chet
Exar-Kun
Car: 2005 350Z
YEAH! so quit buggin me!:p-chet
