will these fit an s13?
hek1620
Car: '89 240sx
17x9 24 and 17x10.5 27. how, or will they fit?
yokota180sx
Car: 1997 Stagea RS4, r34 front
you will need spacers to clear hte brakes,
but you could do it. the rear will be kinda sunken....but thats to me
hek1620
Car: '89 240sx
but they'll work right? that's all i care about. if i need spacers to get it to sit nice, it's nothing that hasn't been done. i was hoping u would chime in. it seems like u have experience with offsets and this type of crap. i'm going to use q45 front brakes and a 5 lug swap. that's probably irrelevent. but, i was thinking of 225's on the 9's and something like 255's on the 10.5's. i want to run a stretched tire(more so in the rear) but i want the rim to still be off the ground. the rear taller than the front. what sizes do u think would be good. also what spacers would i need to get the wheel/tire combo close to the (rolled not pulled) fender. i don't want to pull. i like the "omg it's so close to the fender" look. thanks.
yokota180sx
get a 20 fornt spacer, and a 25 rear spacerroll your fenders you will be fine...a slight pull throw some camber, youll be a baller in no time lol
run a 225-40 on the front, 235-40 on the rear
dont even think of other sizes
hek1620
Car: '89 240sx
235 on a 10.5?! damn, i gotta see that.
yokota180sx
i just pulled a 235 off an 11J
that was a Pain in the *** to get off
hek1620
Car: '89 240sx
yeah, f. that. i think i'll do 245-255 on the 10.5. would i need extended lugs to fit the spacers? i just thought of that.
yokota180sx
depending on your wheels, you might need a 3mm spacer behind the bolt on spacer. but if your whels have hte etra holes for spacer studs to go through, then you will be fine
you will be fine, you ionly need extended lugs when you use sandwich spacers
yoko, just wanted to publicly thank you for being helpful and cool to the n00b.
Nice work. It's noticed and appreciated.
yokota180sx
trying to be a contributing member greg!
JDM is indeed ghey.
yokota180sx
well you dont have viceroy to help people (they do believe it or not) so i do my best lol
whiterps13
Car: white LE hatch
yokota180sx wrote:well you dont have viceroy to help people (they do believe it or not) so i do my best lol
I dont believe it. I'll agree with Greg, you do a nice job helping us out in the Wheels/Suspension forum. You definately know more about crazy sized wheels than me, but I also try to help out as much as possible.
hek1620
Car: '89 240sx
who the hell y'all callin noob? i'm old g 240sx. i had one back when i was 3 y.o.. =) so what kind of spacer will i need? i didn't know there were different kinds. o.k. for some things i'm pretty noobie.
whiterps13
Car: white LE hatch
Yeah, there are differant types of spacers. The sandwhich type spacers simply goes between the wheel and the hub, still retaining the stock lugs. These should only be used for 3 or 5mm applications, as they reduce the amount the lug nut can be tightened.
The kind you want are bolt-on hubcentric spacers. These bolt on to the factory lugs, but have differant lugs attatched that the wheel bolts on to. The best brand, from common concensus, seems to be H&R.
yokota180sx
brand doenst really matteri can get you a set of 20mm bolt ons for 100 bucks+10 shipping
hek1620
Car: '89 240sx
thanks guys. so if i need like 25, i would get a 20mm bolt-on and a 5mm sandwich? straight, know that i got the knowledge it's time to start buying $hit.
yokota180sx
exactly
or a 25 bolt on
hek1620
Car: '89 240sx
i just took my new 4 lug rotors to to be 5 holed. and my q45's to be drilled for 4. about 90 bucks. but f. it. i'd rather them be right than to pay less and then have to buy new ones. next is the 5 lug swap and wheels.
