My little brother is going to join the army and sell his 89 240 coupe. Its in really bad condition he probably wont get much for it, but it has a set of enkei rs5's on it that are 17's. I would think they should fit since they fit on his, but his alignment is all sorts of messed up, which i assumed probably came from his messed up aftermarket suspension held on by some random bolts the guy before him used, the whole car is full of wrong sized bolts and stripped bolts and all sorts of fun. I looked up the rims on
http://www.enkei.com and they only have two sizes for the 4 lug variety, the offsets are 40 on both of them, and the only difference between the 2 are the bolt patterns, one with 4X100/114.3 and the other 4X100/108, both have same bore dia. (72.62). So will either one of those fit my stock 92 240?
They arent exactly the rims i would have picked but theyll be a lot cheaper this way. I dont know much about fitting rims but a friend of mine had a dodge stealth and went through like 4 sets of wheel bearings in one year cause he just tossed some random rims he found lying around on his car. Thats what he told me at least...Anyways any input is appreciated
