Will the waterpump leakage hurt engine?
boris_hu
1994 J30t125000 milesRiverside CA
There is no coolant leakage when the car parks(even after several nights). But some coolant leaks when leaving the parking place. The engine temperature is normal when driving on freeway. I went to gargage and got the conclusion that the waterbump leaks.
So now I will check the coolant level before my departure everytime. Will the small waterbump coolant leakage hurt the engine? or other parts? Thanks.
BTW, what's the normal tire pressure for J30t(The max pressure of my tire is 35 psi)? I didn't find it in my owner manual.
Thanks a lot.
squeefoo
Car: 1990 Infiniti Q45
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
Make sure that's what leaks; and then replace it. It'll just get worse and worse, if it goes long enough little metal particles start floating around, you've got a little time to get ready. Change the A-freeze and the thermostat as long as you're at it, look at the belts too.
driverdriver
Car: NICO's longtime resident Canuck!!!
It's a little bit like playing russian roulette, my brother had a car where the water pump was leaking, he drove it for many months watching the temperature gauge. One day he was on the highway, I guess the coolant corroded some metal and rubber part around where the water pump was attached. The whole thing basicaly gave out and my brother basically cooked his engine by the time he made it to the shoulder.
I would get it changed ASAP, the replacement engine cost in a J30 is very expensive new or used.
Besides you live in California where it is always warm, this will heighten the risk.
squeefoo
1999 Infiniti I30
DriverX2 reminded me : The pump can also seize and fry the belt in just a few seconds, seen that too.
Chally
Car: '94 Infiniti Q45
2002 Nissan Patrol 4.8L
2013 Citroen C4 (economy)
Just get the job done & drive with confidence. I've seen too many "small leaks" seizing engines. It just ain't worth it.
boris_hu
Thanks a lot. I will get it done soon.
natsoundup
I think I got an oem water pump at NAPA for about 100 bucks.... doesn't take too long to do...
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Joe's OEM Is $93ish
