Will the SR20 Valve Cover Fit the KA24DE?
jamied311
Car: 91 Nissan 240SX Fastback
the topic says it all! let me know thanks
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
No.
S13 and S14 KA24DE valve covers are even different...SR...no chance.
If you saw a pic it'd be obvious why.
- Brian
AelSic
Car: 2006 Titan Crewcab
You're not going to rice it are you? "Yeah I got an SR under the hood, she's pumping out 300 horses"
brisknfade
Car: NB8C FTW
:: orion :: wrote:No.
- Brian
So then a s13 KA24de cover wont fit on an S14 KA24de at all? I think i saw somewhere that one or so of the bolts wont fit but it would, but i cant find the thread where it was mentioned. I picked up a s13 valve cover at the junk yard that i wanna polish up and paint and swap with s14 ka cover when i change the gasket so i dont have to wait so long for the paint to dry.
:: orion ::
No, S13 and S14 valve covers ARE NOT at all interchangebale...I mean...it may lay flat, but the middle bolts on top will not line up, and the S14 head had an extra hole in the rear...so the valve cover gaskets are different.
Basically, the S14 has 2 bolts in the middle on top, and one in the rear-center of the head. The S13 valve cover has no bolt on the rear of the head, and 3 in the middle up top.
And the valve cover bolts are different as well, and they determine gasket sealing (they bottom out as a desired depth to make the gasket sit perfect).
Sorry.
- Brian
