Leadfootedone »
https://forums.nicoclub.com/leadfootedone-u66965.html
Sat Apr 24, 2010 5:55 pm
Yes it will work fine, you have to get it down to a long block and use everything from your Z, You also need to use the oil pan and pickup from your Z as the J30 has the front subframe in a different possition. While you're at it if it's a used motor change the cam, crank and rear main seal... Oh and swap the exhaust manifolds, and upper intakes obviously. Also change the oil filter mount, you'll need to make a tool that looks like a broad flathead screw driver to remove the sleave for the filter mount to use on the j30 block. I think thats it, It's been a few years...
