Will the cluster work, or send it to McKinney?
curbsurfer253
Well my S14 Rb25 swap is nearing completion and I'm starting to get worried about the cluster. I do not have the R33 cluster to swap in and I don't have the electrical know-how to completely re-wire the thing. Should I just send it to McKinney? Does anyone know the turnaround on one if I sent it to them and does anyone know how much is cost? Thanks a lot for any input guys
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
your speedo/tach will be wrong, but everything else should work fine. (on the RB25/S13 i have to swap out the temp sendor on the motor for one from an S13, but i am not sure if you will need to do that on the S14)
I heard someone say it was $100 to have the tach/speedo fixed. Give mack a call and they should be able to tell you.
I went the alternate route and sourced a tach from a junkyard, and did some speedo modifications. With all the work it took to get it right, I would probably just pay mckinney to get the stck one reading right.
kevy8up
go click on their site on the left side of this page and check them out, look under SALE and go down to wiring services.
curbsurfer253
thanks guys, do they convert the speedo to 180mph too? i don't remember where I heard that.
NISMO_RB25
you will have to give them a call or send an email. I saw that someone on here had them fix the cluster, but I don't know if they actually change the gauge, or just add an adjuster.
