will the air compressor match up?
Kundo240
Car: nissan 240sx 1990
Hi, thinking of buing a ca18det, wondering if the air compressor will match up or will I have to do some custom modification for itto fit?
nnkfws333
Car: 2004 Infiniti G35 and a 1989 Nissan 240SX
Are you referring to the AC Compressor? Which one?
Kundo240
sorry meant to say ac compressor.... so will it match up or custom modification will have to be done?
biosehnsucht
which AC compressor? are you asking about the mounts, the AC hoses, the belt pully.. ?
NeedCAforS13
Car: CA swapped S13 coupe
Kundo240 wrote:some custom modification for it to fit?
yes. nothing bolts right up... some people claim KA24E stuff works, but I have yet to see proof, or a hear of a running example.
Sean
Kundo240
would there be anything I can do to be able to keep my a/c. thanks....
Dattebayo
Your current ac could be kept by having a custom bracket made up by a fabricator or welding shop.
Or you could look around to see if someone will sell you the stock JDM compressor, then you could have that one adapted to fit the current lines and equipment that already are installed with your car now.
em55ery
Car: 91 nissan 240sx
i have a compressor mounting bracket and a portion of the lines from my ca18 if you want them or if anyone does
float_6969
It can work, but you need KA-E parts. If you use the CA bracket, bolted to the CA block you can bolt the KA-E pump to it w/o any problems. The problem lies in the way that the pully lines up on the pump. The KA-E pump pully doesn't line up with the spot on the CA crank pully. BUT all you would have to do is take the CA pump and the KA-E pump down and have the CA pully swapped onto the KA-E pump. I know this will work, and can be done. What I don't know is if the KA-E fittings are the same as the KA-DE fittings. Plus you'd have to figure out the wiring, which I never got around to. If you're intrested, I've got a CA pump.
