will the adjustable tension rods and struts for a q,240,300 ect fit a j
kccake
Car: i994 infiniti j30
will the adjustable tension rods and struts from a q,240,300 ect fit my 94 j30????
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
yep.
kccake
without any modifacation???? and the struts will fit too as there is a 93 q45 in a junk yard in nova scotia with all new tokio struts!!! thanks ke
elwesso
2007 BMW M Coupe
the tension rods will, cant say the struts will.
driverdriver
Car: NICO's longtime resident Canuck!!!
I don't think the struts will fit. There was a thread about this awhile ago. I can't find it.
daltonnnn
Car: 1993 Infiniti j30
Since we are on the subject of suspension, does anyone know if the rear toe and camber arms are the same for J30 to s13, s14?
DominickJ30
Car: 1993 Infiniti J30t
daltonnnn wrote:Since we are on the subject of suspension, does anyone know if the rear toe and camber arms are the same for J30 to s13, s14?
Side note daltonn, but I always thought the Js chassic code was YJ32, not Y21
daltonnnn
Well, from what I have seen, the arms are pretty close, if not identical to the s13, 14 chasis. I am seeing if anyone ever researched it so I wouldn't have to be the first.
The chassis code is y21, check your vin number. Unless the japanese code is that.
Anyways, if anyone did, let me know. I am going to roll my rear fenders and want some more positive camber so yeah.
elwesso
2007 BMW M Coupe
the chassis code for the J30 is JPY32.. thats what it says in the FSM and in the parts book
DominickJ30
Its actually just Y32, the JP stands for japan I think.
elwesso
2007 BMW M Coupe
technically your right, but not really right...
The J30 is the Y32 series (chassis).. You cant call it a y32 because there are other Y32s, such as the cima and so forth...
The Infiniti J30 is the JPY32
DominickJ30
Ok so then I assume that only the leopard j fearie shared the JPY32 chassis code?
elwesso
2007 BMW M Coupe
The JPY32 may have only been the North american J30... Its hard to say.....
on the Y33 Q's they list them as FY33 in the FSM, and FGY33 in the parts book...
